查看: 2424|回复: 10
求南非插头标准 SABS 164-1:2007 (已应助)
发表于 2012-2-2 11:47:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求 南非插头标准 SABS 164-1:2007, 请大家帮忙!
发表于 2012-2-2 11:47:17 | 只看该作者
这里有:
SANS 164-0:2006
SANS 164-1:2006
SANS 164-2:2006
 楼主| 发表于 2012-2-2 11:47:23 | 只看该作者
Thanks 1楼 wongyatwah, 我已有2006版本的, 目前需求2007的版本或更新的。
发表于 2012-2-2 11:47:29 | 只看该作者
官方网站显示,有部分是2007年更新了,还有2008年更新的:
https://www.sabs.co.za/Business_ ... ults.aspx?search=qs
搜索出来的内容:
Back to Quick search | Back to Advanced search Print friendly
1 to 7 of 7 records found
DOCUMENT EDITION PDF HARDCOPY
SANS 164-0:2007 1.01
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 0: General and safety requirements ( 47,862 bytes (small file))
Click here for more information and pricing
SANS 164-1:2007
(SABS 164-1) 5.01
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 1: Conventional system, 16 A 250 V a.c. ( 136,053 bytes (small file))
SANS 164-2:2006
(SABS 164-2) 3.00
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 2: IEC system, 16 A 250 V a.c. ( 646,779 bytes (large file))
SANS 164-3:2007 1.01
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 3: Conventional system, 6 A 250 V a.c. ( 187,188 bytes (small file))
SANS 164-4:2007 1.01
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 4: Dedicated system, 16 A 250 V a.c. ( 288,180 bytes (small file))
SANS 164-5:2007 1.01
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 5: Two-pole, non-rewirable plugs, 2,5 A 250 V a.c., with cord, for connection of class II equipment ( 146,241 bytes (small file))
SANS 164-6:2008 1.01
Plug and socket-outlet systems for household and similar purposes for use in South Africa Part 6: Two-pole systems, 16 A 250 V a.c., for connection of class II equipment
发表于 2012-2-2 11:47:35 | 只看该作者
谁能发个6A的小南非插头尺寸图给我看看啊,万分感谢
 楼主| 发表于 2012-2-2 11:47:41 | 只看该作者
真的很难找, 请大家帮忙!!! 先谢!!
SABS 164-1:2007或 SANS 164-1:2007
发表于 2012-2-2 11:47:47 | 只看该作者
可惜呀,安规威望不够,下不了
发表于 2012-2-2 11:47:53 | 只看该作者
怎样才能有足够的钱来下载这东西啊
发表于 2012-2-2 11:47:59 | 只看该作者
非常感谢呀!感谢发帖!
发表于 2012-2-2 11:48:05 | 只看该作者
威望不够啊
GMT+8, 2026-10-25 10:06 , Processed in 0.101116 second(s), 19 queries , Gzip On.
