查看: 680|回复: 7
电源线型号认识
发表于 2012-2-2 11:25:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Flat Wire:
SPT: Stranded, Parallel, Thermoplastic
This is always followed by a -1, -2 or -3, signifying insulation thickness for different applications.
HPN: Heater, Parallel, Neoprene
Required for heater-type application, such as irons, toasters, etc.
NOTE: We can run some 20 AWG, but mostly we run 18, 16 and 14 AWG, 2 or 3 conductors.
P is always Parallel Wire (Flat).
Jacketed Wire:
S = Stranded (or Service Wire)
J = Junior Service (300 Volt). If no "J" is in the wire type, then it is a hard service (600 Volt).
T = Thermoplastic. If no "T" is in the wire type, then it has a rubber jacket.
O = Oil-Resistant Compound
W = Weather-Resistant Compound
V = Vacuum - as in vacuum cleaner. This is a small O.D. jacketed wire, very flexible and initially used for vacuum cleaners but now used on many different types of products. Available only in 18 AWG.
Examples:
SV = Stranded Vacuum Rubber Jacketed (NO "T")
SJT = Stranded Junior Thermoplastic
SJTOW = Stranded Junior Thermoplastic, Oil and Weather resistant for UL and CSA.
Miscellaneous requirements:
S.P. = Surface Printed
N.M. = Non-Migratory compound to prevent the wire color from bleeding under unusual circumstances.
VW-1 = Vertical Flame test (formerly FR-1)
60°C = Standard temperature rating (except HPN - 90°C
105°C = Electri-Cord's alternate rating (we normally don't stock 75°, 90°C)
IEC, ICC = International Color Code on the inner conductors (Blue, Brown, Green w/Yellow Stripe)
N.A. = North American Color Code on the inner conductors (Black, White, Green)
41/34 = Stranding - 41 strands of 34 AWG wire for each inner conductor
T.C. = Tinned Copper inner conductors
RIBBED = Outer jacket is striated with ribs
R/S or W/S = Red or White Stripe for visual polarity inspection on Flat wire
发表于 2012-2-2 11:25:59 | 只看该作者
很好的解释
发表于 2012-2-2 11:26:06 | 只看该作者
很受用
收下了~
发表于 2012-2-2 11:26:12 | 只看该作者
很好,很受用
发表于 2012-2-2 11:26:18 | 只看该作者
怎么是英文哦,
发表于 2012-2-2 11:26:24 | 只看该作者
楼主关于美规电线的描述是很清晰的哟!谢谢主!
发表于 2012-2-2 11:26:30 | 只看该作者
非常感谢!
发表于 2012-2-2 11:26:36 | 只看该作者
楼主蛮细致
GMT+8, 2026-11-30 16:33 , Processed in 0.027290 second(s), 18 queries , Gzip On.
