查看: 508|回复: 5
ul绝缘电阻
发表于 2012-2-2 10:24:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问ul不带w电线的绝缘电阻是不是仍是2.5M了?还是有更新,谢谢!
发表于 2012-2-2 10:24:53 | 只看该作者
什么标准里面的
发表于 2012-2-2 10:24:59 | 只看该作者
说的是ul62吧,是2.5MΩ*KFt
 楼主| 发表于 2012-2-2 10:25:05 | 只看该作者
仍是2.5MΩ*KFt,怎麽我们公司工程师说修改为150了呢?没看到标准更新啊!
发表于 2012-2-2 10:25:11 | 只看该作者
2.5应该是正确的,不可能改为150什么的吧,可能是针对其它的东东,可具体查查标准啦!
发表于 2012-2-2 10:25:17 | 只看该作者
没有看到更新的呀.
UL62-2006的条款:
5.2.3 Insulation resistance
5.2.3.1 Insulation resistance for all ²W² Type cords at 15°C
The insulation resistance of the insulated conductors shall be not less than shown in Table 47 or 48 when
a specimen of at least 15 m (50 ft) of the finished cord is tested in water at 15 °C immediately following
the dielectric strength test described in Clause 5.2.2. If tested at temperatures different than 15 °C, the
values shall be corrected to 15 °C.
5.2.3.2 Insulation resistance for all indoor cords at room temperature
The insulation resistance of the insulated conductors shall be not less than 0.76 GΩ?m (2.5 MΩ?1000 ft)
at 15 °C when a specimen of the finished cord at least 15 m (50 ft) in length is tested in air at 15 °C or
higher after conditioning for at least 6 h and immediately following the dielectric strength test described in
Clause 5.2.2.
5.2.3.3 Test method
Compliance with all insulation resistance tests shall be determined in accordance with the method
described in CSA C22.2 No. 0.3, Clause 4.28.2.1 and Table 15; UL 1581, Section 920; or
NMX-J-294-ANCE.
谁有更新的版本有修改这个内容的信息的吗?
GMT+8, 2026-11-30 16:44 , Processed in 0.026744 second(s), 18 queries , Gzip On.
