查看: 512|回复: 1
问题求助 - 滚桶测试
发表于 2012-2-2 10:12:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁知道 是否 Plug portion test 要做滚桶测试?
产品是 AC-DC adaptor.
是欧洲插头部分.
发表于 2012-2-2 10:12:43 | 只看该作者
如果你的是 BS type plug 就要根据 BS 1363-1 做 tumbling barrel 测试
20 Mechanical strength
Plugs are tested in the tumbling barrel shown in Figure 20. The barrel is turned at a rate of approximately 5 r/min, (approximately 10 falls per minute).
GMT+8, 2026-11-30 16:44 , Processed in 0.028549 second(s), 18 queries , Gzip On.
