查看: 496|回复: 1
UL2547 号线的额定电压应该是多少
发表于 2012-2-1 12:32:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前辈:
UL 2547 额定电压应该是多少? 在那个标准里面可以查到啊?
因为我不是从事电线行业的,对这方面的知识了解太少,所以咨询各位一下,小女子先谢了.
发表于 2012-2-1 12:32:12 | 只看该作者
发一张UL758里对于2547的规定看看~
希望下列的英文都能认识。
刚在UL的规格页里下的更新后的。
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 2547 Issued: 1971-10-15
Revised: 2003-03-31
Style 2547 Two or Three Conductor-Semi-Rigid PVC Insulated
and PVC Jacketed Wire.
______________________________________________________________________________
Rating 80?C, voltage not specified.
Conductors Two or three 30-16 AWG, solid or stranded, tinned
or bare copper.
Insulation Extruded semi-rigid PVC, 9 mils minimum average,
7 mils minimum at any point. Suitable for 80?C.
Assembly Insulated singles parallel, twisted, or cabled
together, length of lay is not specified.
Barrier layer and/or fillers optional.
Shield Optional.
Jacket Extruded PVC, Class 43, 12 mils minimum average,
10 mils minimum at any point. ______________________________________________________________________________
Shield Optional.
Jacket Optional. Extruded PVC, Class 43, 12 mils minimum
average, 10 mils minimum at any point.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties of Insulation and Jacket, Unaged.
*Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties of Insulation and Jacket.
Program (4) Heat Shock.
(4) Cold Bend.
(4) Deformation.
* (12) Horizontal Flame Test.
Marking General.
Use Internal wiring of electronic equipment where not
exposed to movement or mechanical abuse.
GMT+8, 2026-8-6 21:52 , Processed in 0.116270 second(s), 18 queries , Gzip On.
