查看: 784|回复: 7
电线样品印字不全
发表于 2012-2-1 12:27:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大虾,晚上好!
一客户提供给我一款电线样品,但是上面印字不全。我现摘录如下,各位帮我看看是什么意思,我就如同看天书一样啊~~~
...THWN GASOLINE AND OIL II 600V (UL) OR AWM VW-1 AIW-K C(UL) TYPE T90 NYLON OR TWN75 FT1
谁能告诉我一下TWN75 FT1是什么意思吗?我花了一天的时间终于搞明白了VW-1的意思,呵呵。
另外,谁知道这款电线哪里有卖啊??
拜托了,各位!!
发表于 2012-2-1 12:27:39 | 只看该作者
THHN, MTW, THWN-2, AWM
T90 Nylon, TWN75 (cUL)
Thermoplastic Insulated, Nylon Sheathed Heat, Moisture, Oil & Gasoline Resistant 600 Volt Copper
Product Description:
Alan Wire Type THHN or THWN-2 conductors are primarily used in conduit as branch circuits in commercial or industrial applications, as specified by the National Electrical Code. Type AWM or MTW conductors are primarily used as appliance or machine tool wiring, as specified by the National Electrical Code.
Type THHN or THWN-2 are available as stranded in sizes 14 awg - 750 kcmiL, and as solid in sizes 14-10 awg. Stranded sizes 14 awg - 750 kcmil are also rated as AWM or MTW. The conductors are soft-annealed, stranded or solid copper and are insulated with a tough, heat and moisture resistant polyvinyl chloride (PVC), over which a nylon (polymide) jacket is applied.
Specifications:
Alan Wire Type THHN or THWN-2 or AWM or MTW meets applicable ASTM specifications, UL Standard 83, UL Standard 758, and UL Standard 1063. The conductors are Gasoline and Oil Resistant II, and have a voltage rating to 600 volts.
Sizes 1/0 and larger are rated for CT use. All sizes have VW1 flame rating. All THHN is UL and cUL Listed.
Conductor PVC Insulation Thickness (Mils) Nylon Jacket Thickness (Mils) Nominal O.D. (Mils) Ampacity Approx. Net Weight per MFT Color Code Standard Package
Size AWG No. Strands 90° C THWN-2 90° C THHN
**14 Solid 15 4 102 15 15 16 1 AE
**12 Solid 15 4 119 20 20 24 1 AE
**10 Solid 20 4 150 30 30 37 1 BE
14 19 15 4 112 15 15 16 1 AE
12 19 15 4 131 20 20 24 1 AE
10 19 20 4 165 30 30 37 1 BE
8 19 30 5 218 45 50 64 2 B
6 19 30 5 256 65 70 96 2 CD
4 19 40 6 325 85 90 155 2 CD
3 19 40 6 345 100 105 190 3 CD
2 19 40 6 388 115 120 235 3 CD
1 19 50 7 437 130 140 300 3 CD
1/0 19 50 7 477 150 155 370 3 CD
2/0 19 50 7 521 175 185 465 3 CD
3/0 19 50 7 571 200 210 570 3 CD
4/0 19 50 7 627 230 235 720 4 CD
250 37 60 8 711 255 290 850 5 CD
300 37 60 8 766 285 320 1011 5 CD
350 37 60 8 817 310 350 1172 5 CD
400 37 60 8 864 335 380 1333 5 CD
500 37 60 8 949 380 430 1653 5 CD
600 61 70 9 1051 420 475 1985 5 CD
750 61 70 9 1126 475 535 2462 5 CD
A - 2000' Carton, Four 500' Spools Per Carton ** Not Suitable for MTW Applications
B - 1000' Carton, Two 500' Spools Per Carton
C - 500' Reel D - 1000' Reel E - 2500' Reel Other lengths available upon request.
Colors Available:
Color Code #1) Black, White, Red, Blue, Green, Orange, Yellow, Brown, Purple, Gray, Pink, Tan
Color Code #2) Black, White, Red, Blue, Green, Orange, Yellow, Brown, Gray
Color Code #3) Black, White, Red, Green
Color Code #4) Black, Green
Color Code #5) Black
美国WWW.ALANWIRE.COM公司有生产.国内可能没有.
发表于 2012-2-1 12:27:45 | 只看该作者
简单说,TWN75是加拿大的线材称号,类似於美国的THWN线材,
FT1(Flame Test 1)垂直燃烧测试,是线材燃烧测试的一种要求,打上这符号表示此线能符合FT1要求。
其他如1楼所说的。
发表于 2012-2-1 12:27:51 | 只看该作者
利害,真长了见识。不过电线上标了这么多东西,说明该电线通过了这些测试。CUL后面对应的都是跟UL几乎相同的测试项目。
 楼主| 发表于 2012-2-1 12:27:57 | 只看该作者
谢谢ewardyan和炎黄的详细解释,谢谢!
还有,哪位知道哪里可以买到这种线呢?
发表于 2012-2-1 12:28:03 | 只看该作者
还有,哪位知道哪里可以买到这种线呢?
如果你知道怎麽搜寻的话,上网搜寻就有了,很多交易网站都能找到这类供应商的。
 楼主| 发表于 2012-2-1 12:28:10 | 只看该作者
我搜过,但国内的没发现。我搜到的都是国外的:(
发表于 2012-2-1 12:28:16 | 只看该作者
我上面不是已经说过了国内没有厂家生产的.因为国内申请认证的产品都是常见UL规格.这是特殊点的.而且是尼龙料做的,国内好象还没有用尼龙做电线的吧.
GMT+8, 2026-11-30 16:55 , Processed in 0.071082 second(s), 18 queries , Gzip On.
