查看: 371|回复: 1
求助AWM1230
发表于 2012-2-1 12:09:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好,我现在急需了解UL758中的AWM1230这款电线的规格,材料等资料,请大家帮帮忙啦,谢谢!
发表于 2012-2-1 12:09:47 | 只看该作者
请多利用UL的查询资源!
http://database.ul.com/cgi-bin/XYV/template/LISEXT/1FRAME/cawmsrch.html
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 *Page 1230 Issued: Dec. 2, 1960
Revised: Oct. 30, 2000
Style 1230 Nominal 1/32-inch Thermoplastic (PVC) - Insulated Wire.
____________________________________________________________________________
Rating 105°C, Moisture Resistant, 60°C, 600 Volts.
Conductor 26 - 9 AWG. Solid or stranded, tinned or bare copper.
Insulation Nominal 1/32-inch wall Thermoplastic (PVC) Type
TW. Also suitable for 105°C in air and 60°C or
80°C in oil, if applicable.
______________________________________________________________________________
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, unaged.
Representative Dielectric Strength and Insulation Resistance Tests
same as TW.
(12) Insulation Resistance at 60°C.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties, unaged.
Program (4) Heat Shock.
(4) Deformation.
(4) Cold Bend.
(4) Flame Test.
(4) Specific Inductive Capacity at 30°C.
Marking General.
Use Internal Wiring of Appliances, or where
exposed to oil at a temperature not exceeding
(60°C or 80°C, whichever is applicable). Moisture
Resistance, 60°C.
GMT+8, 2026-5-1 14:09 , Processed in 0.115172 second(s), 19 queries , Gzip On.
