查看: 499|回复: 4
UL20#1007电线要求
发表于 2012-2-1 11:08:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教:
UL20#1007电线有多少根线芯?外径多少?耐温和耐压多少?对电阻有要求吗?
发表于 2012-2-1 11:08:07 | 只看该作者
导体用:26/0.16MM,外径:1.8MM,耐温80度300V,电阻有要求的,可以查UL1581
发表于 2012-2-1 11:08:13 | 只看该作者
看一下这个就明白啦。
Style 1007 Polyvinyl Chloride Insulated Wire.
______________________________________________________________________________
Rating 80?C, 300 V.
Conductor 32-16 AWG, solid or stranded.
Insulation Polyvinyl Chloride, 15 mils minimum average,
13 mils minimum at any point, 60 or 80?C in oil,
if applicable.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, Unaged.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Cold Bend
* (4) Deformation.
* (12) Horizontal Flame Test.
Marking General.
Use Internal wiring of appliances; or where exposed to oil
at a tempera¬ture not exceeding 60°C or 80°C, whichever
is applicable. Tags may indicate the following:
600 V Peak - For Electronic Use Only.
导体UL只要求绞合截面积,导体在UL1581的导体章节有讲到,你可以查一下。
发表于 2012-2-1 11:08:19 | 只看该作者
我补充一下电阻要求,20AWG允许最大导体电阻34.6
 楼主| 发表于 2012-2-1 11:08:26 | 只看该作者
谢谢hli168!收下了.
在论坛里收获太多,一切尽在不言中!
GMT+8, 2026-11-30 17:42 , Processed in 0.042766 second(s), 18 queries , Gzip On.
