查看: 479|回复: 1
带surge的六孔插座一般来讲需要什么样的marking
发表于 2012-2-1 10:58:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
带surge的六孔插座一般来讲需要什么样的marking? ( Canadian mart)
我参考了UL498A,
但是其中只有一般性的要求,
在UL498A, 7markings中,只要求
7.1.1 A device shall be legibly and permanently marked with:
a) The company’s name, trade name, or trademark or other descriptive marking by which the
organization responsible for the device is able to be identified.
b) The electrical rating. See also 7.3.1.
c) The catalog number or an equivalent designation, where practicable.
Exception: The catalog number is not prohibited from appearing on the unit container when the
product is too small, or where the legibility is difficult to attain, or where several catalog numbers
use common parts.
d) The markings specified in 7.2 – 7.9 as applicable.
但是在7.2-7.9中没有发现有讲surge的
请请教一下!是否还有一些其它的marking required
发表于 2012-2-1 10:58:33 | 只看该作者
顶一下,另外请教surge值是怎么定的?
GMT+8, 2026-11-30 17:42 , Processed in 0.025701 second(s), 18 queries , Gzip On.
