查看: 12046|回复: 121
玩具验货通用英语实语
发表于 2007-6-17 17:12:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
outfit wet 公仔衫湿
outfit shrinkage 公仔衫缩水
outfit fade 公仔衫褪色
outfit unfit 公仔衫褪色不合身
poor cutting 剪裁不良
poor sketching 钉缝形状不良
poor sewing 车缝不良
poor stitching 缝合不良
poor embroidery 绣花不良
poor brushing 梳发不良
poor plush 织毛不良
poor stuffing 入棉形状不良
poor shape 外形不良
poor hair styling 发形不良
poor hair cutting 头发剪 裁不良
poor hot stamping 热烫不良
poor hand stitching 手缝不良
uneven shape 形状不对称
low dense stitching 车缝太疏
high dense stiting 车缝太密
seam torn 缝口撕裂
seam open 缝口爆开
missing marrow 漏车骨
jumping stitches 跳针
stitching hole 针孔
pucker 缝边皱起
sewing machinery mark 衣车钳印
long loose hair 长松头发
long loose thread 长松线头
velcro detach 魔术贴脱落
sewing label loose 标签松脱
materials run 物料走纱
maaterials torn 物料烂
over stuffing 入棉过多
poor marrow 车骨不良
under stuffing 入棉不足
stuffing disproportion 入棉比例不对
uneven stuffing 入棉不均匀
stuffing expose 棉料外露
pile trapped by seam 长毛夹于缝口
thread trapped by seam 长线夹于缝口
hair trapped by seam 头发夹于缝口
bald spot on plush 毛发脱落露底
color migration 经摩擦脱色
color mismatch 颜色不匹配
color deviation 颜色偏差
fabric texture mismatch 布料组织不对
ribbon fray 丝带散口
materials fray 物料散口
fabric fray 布料散口
lable peel off 贴纸翘起
seam allowance expose 纸口外露
fabric torn 布料烂
fabric w/punch mark/hole 南皮料有孔或洞
face cover up 遮住脸部
face distortion 脸部歪曲、变形
poor blushing 颊红喷油不良
foreign stuffing 外来填充料
hair too long 头发太长
hair too short 头发太短
messy hair 头发凌乱
missing sewing label 漏车缝标签
over size 尺寸过大
under size 尺寸不够
poor dressing 衣着不良
poor hair rooting 植发不良
yarn run 走纱
hair covers eye 头发遮住眼睛
missing parts 漏装配件
missing component 漏装附件
missing date code/week code 漏印日期或星期码
missing whole pack of accessory 漏装整包配件
wrong packaging 包装错误
packaging damaged 包装损坏
packaging wrinkled 包装皱
carton mark illegible 箱印模糊
gift box illegible 彩盒印刷模糊
story book illegible 故事书印刷模糊
instruction sheet illegible 说明书印恻模糊
blister card illegible 吸塑卡印刷模糊
date code/week code illegible 日期/星期印刷模糊
blister poor heat sealing 吸塑热封不良
blister unseal 吸塑未封口
incorrect blister 吸塑不对
blister damaged 吸塑烂
burn mark on blister 吸塑烧焦
blister crack 吸塑裂
blister crushed 吸塑压皱
blister deformed 吸塑变形
blister detached 吸塑用脱
blister shrinkage 吸塑缩水
blister undershot 吸塑走料不足
incorrect blister card 吸塑卡用错
fold mark on blister card 卡有折痕
outfit sealed on blister 公仔衫夹于吸塑中
blister card wet 吸塑卡湿
burn mark on blister card 吸朔卡有烧焦痕
blister card delimitation 吸塑卡纸内层分离
blister card poor die-cut 吸塑卡裁剪不良
blister card wrong die-cut 吸塑卡裁剪错误
blister card wrinkle 吸塑卡皱
blister card damaged 吸塑卡烂
blister cannot stand properly 吸塑不能完全站立
packing defect
Defect Description(次品描述) Chinese Meaning(中文意思)
polybag damaged 胶袋烂或穿孔
polybag poor die-cut 胶袋剪裁不良
missing vent holes on polybag 胶袋漏打出气孔
polybag not sealed/taped 胶袋未封口
polybay too thin 胶袋太薄
incorrect polybag 胶袋不对
j-hook damaged 挂钩烂
j-hook wrinkle 挂钩皱
j-hook poor die-cut 挂钩剪裁不良
j-hook sticker dislocated 挂钩贴胶移位
j-hook sticker exposed 挂钩胶贴凸起
butterfly hook damaged 蝴蝶孔烂
butterfly hook wrinkle 蝴蝶孔皱
butterfly hook poor die-cut 蝴蝶孔剪裁不良
butterfly hook delaminating 蝴蝶孔内层分离
windown box film damaged 彩盒胶窗烂
windown box film stress 彩盒胶窗顶白
windown box film detached 彩盒胶窗甩脱
windown box film poor sealing 彩盒胶窗粘合不良
windown box film  poor transprent 彩盒胶窗透明度不良
white mark windown box film 彩盒胶窗发白
dent mark windown box film 彩盒胶窗有凹痕
gift box flap seam open 彩盒缝口爆开
gift box crushed 彩盒压烂或压皱
gift box deformed 彩盒变形
gift box wet 彩盒湿
gift box unseal 彩盒未封口
gift box crumple 彩盒弄皱
fold mark in gift box 彩盒有折痕
tape poor sticking 胶纸粘合不良
as receive small part 细小物体
small part of insect 昆虫等细小物体
screw came off 螺丝脱落
small part of broken piece 细小破烂物
sharp point 尖点
sharp point on broken piece 破烂物有尖点
sharp point on spping 弹簧附有尖点
sharp point on gate remnant 水口附有尖点
sharp point on screw's head 螺丝头附有尖点
sharp edge 利边
sherp edge on broken piece 破烂物有利边
sharp edge on screw's head 螺丝头附有利边
sharp edge on meter/battery contact plate 金属或电池片附有利边
puncture hazard 刺伤性危险
pinching hazard 压伤性危险
rigid projection hazard 硬突起物伤害危险
clearace 虚位
missing paint 漏喷油
poor painting 喷油差
poor coating 油漆外层不良
poor touch up 补油差
paint abrasion 喷油擦花
foreign paint 外来飞油
dark paint 颜色深或暗
scratch paint 喷油刮花
paint smear 油污
bubble paint 喷油起泡
paint accumulated 聚油
paint dislocation 喷油不到位
paint glossy 喷油表面光滑
dust paint 喷油有尘
insufficient paint coverage 喷油薄
uneven paint coverage 喷油厚薄不均
over spray 喷油过多
under spray 喷油不足
color migration 摩擦脱色
color mismatch 颜色不配对
color misalignment 颜色不对称
color deviation 颜色有偏差
dull color 颜色深
shine color 颜色光亮
poor tempo 移印不良
tempo incomplete 移印不完整
tempo off posttion 移印移位
tempo printing off set  移印套色不良
poor silk screwwn printing 丝印不良
poor electro-plating 电镀不良
electro-plating peel off 电渡脱落
electro-plating yellowish 电渡变黄
electro-plating abrasion 电渡擦花
electro-plating shadow 电渡阴阳色
electro-plating black mark 电渡发黑
electro-plating rainbow 电渡成彩虹印
poor hot stamp 热烫不良
rough surface  喷油表面不平整
poor printing 印刷不良
lacquer accumulation 力架集聚
abnormal sound 杂音
battery/contact spring exposed 电池弹簧凸出
battery/contact spring came off 电池弹簧脱落
contact plate rust 电池片生锈
contact plate exposed 电池片外露
contact plate came off 电池片松脱
contact plate loosen 电池片松
poor contact 接触不良
poor function 功能不良
int-non-function 间歇无功能
mal-function 其中某一功能不良
non-function 无功能
sound too loud 声音太大
sound too low 声音太小
no sound 无声音
weak/no light 灯弱或不能发光
wire exposed 电线外露
wire detached 电线甩脱
wire poor welding 电线焊接不良
short circuit 短路
electric leakage 漏电
battery coil over heat 电池线圈过热
switch poor function 开关功能不良
switch non-function 开关无功能
circuit board damaged 电路板损坏
circuit board non-function 电路板无功能
circuit board loosen 电路板松
poor soldering 焊锡不良
cold solder 假焊
no response on switched on 按动后无反应
no sound on switched on 按动后无声音
light on constantly 灯长明
参与人数 2金币 +15 威望 +13 收起 理由
yinghuochong + 5 + 5 你太有才了
wtoqc + 10 + 8 精品文章
发表于 2007-7-24 22:23:17 | 只看该作者
谢谢楼主分享、、、、、
发表于 2007-7-26 15:38:02 | 只看该作者
好东西,真实用!谢谢楼主!
发表于 2007-7-26 17:49:28 | 只看该作者
对于我这种不懂外语的人来说太有用了
发表于 2007-7-26 19:40:59 | 只看该作者
回复 #1 w8292 的帖子
多謝!
多謝!.....................
发表于 2007-7-27 14:32:55 | 只看该作者
很全面的解释,留着备用,楼主的这种介绍方式值得推广.
发表于 2007-7-29 11:17:29 | 只看该作者
thank you very much!
发表于 2007-7-29 14:08:36 | 只看该作者
不错!不错!!谢谢分享。
发表于 2007-7-29 21:05:56 | 只看该作者
Very good!!
Thanks a lot!!
undefined undefined
发表于 2007-8-13 11:44:41 | 只看该作者
谢谢楼主分享
GMT+8, 2026-10-17 06:52 , Processed in 0.031667 second(s), 20 queries , Gzip On.
