查看: 687|回复: 5
请问LED球泡或者射灯灯杯申请能源之星应采用什么标准
发表于 2012-1-27 18:15:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
采用的标准具体应该是什么呢?
发表于 2012-1-27 18:15:14 | 只看该作者
你先要通过安全(ETL UL)和FCC认证后,才能申请能源之星,能源之星采用LM79和LM80,但好像最近出了一个ENERGY STAR LUMINAIRES V1.0,但这个标准中针对LED产品的TM21 和LM82还没出来。
 楼主| 发表于 2012-1-27 18:15:20 | 只看该作者
我查了一下能源之星网站上的要求:
LED Light Bulbs Key Product CriteriaPerformance Characteristics: Current Criteria:
Correlated Color Temperature (CCT) Nominal CCT: 2700K, 3000K, 3500K, or 4000K
Color Maintenance The change of chromaticity over the minimum lumen maintenance test period (6000 hours) shall be within 0.007 on the CIE 1976 (u’,v’) diagram.
Color Quality (Color Rendering Index or CRI) CRI >= 80, R9>0
Dimming If a product is dimmable, packaging must state this. Minimum efficacy, light output, CCT, CRI, and power factor of dimmable lamps will be confirmed with the lamp operated at full power.
Warranty A warranty must be provided for lamps, covering material repair or replacement for a minimum of three (3) years from the date of purchase.
Allowable Lamp Bases Must be a lamp base listed by ANSI.
Power Factor For lamp power <= 5W and for low voltage lamps, no minimum power factor is required.
For lamp power >= 5W, power factor must be = 0.70.
Minimum Operating Temperature Integral lamp shall have a minimum operating temperature of -20°C or below.
LED Operating Frequency >= 120 Hz
Electromagnetic and Radio Frequency Interference Integral LED lamp must meet the appropriate FCC requirements for consumer use (FCC 47CFR Part 15).
Audible Noise Integral lamp shall have a Class A sound rating.
Transient Protection Power supply shall comply with IEEE C.62.41-1991, Class A operation. The line transient shall consist of seven strikes of a 100kHz ring wave, 2.5kV level, for both common mode and differential mode.
Operating Voltage Lamp shall operate at rated nominal voltage of 120, 240, or 277 VAC, or at 12 or 24 VAC or VDC
好像并没有提到UL的标准.
发表于 2012-1-27 18:15:26 | 只看该作者
能源之星有安全方面的要求---UL1993,针对整体式LED灯的要求,参考V1.3版本要求
发表于 2012-1-27 18:15:32 | 只看该作者
我较赞同1楼godxlalp说的
发表于 2012-1-27 18:15:38 | 只看该作者
有一定要求要做FCC认证吗?我有个项目T8灯管,过了安全ETL认证,但没有过FCC,现在正在做LIGHTING FACTS光电源标签认证呢?
GMT+8, 2026-10-17 03:13 , Processed in 0.031103 second(s), 18 queries , Gzip On.
