查看: 437|回复: 4
UL1993 对于PCB的间隙要求
发表于 2012-1-27 17:36:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL1993对于PCB的间隙没有要求,满足耐压测试即可?
发表于 2012-1-27 17:36:34 | 只看该作者
有呀
in primary circuits,1.5mm minimum spacing are maintained through air and 3.0mm minimum spacing are maintained over surfaces between the current-acrrying parts of opposite polarity on PCB of power unit.And 1.2mm minimum spacing are maintained through air and over surfaces of insulating material between current-carrying parts of opposite polarity and between such current-acrrying parts and dead-metal prats or low voltage isolated circuits.
 楼主| 发表于 2012-1-27 17:36:40 | 只看该作者
有呀
是啊,我就觉得奇怪啊,我是在以份培训资料里看到说满足耐压就可以了
发表于 2012-1-27 17:36:46 | 只看该作者
有要求,电气间隙,和爬电距离都有要求,不只是满足耐压
发表于 2012-1-27 17:36:52 | 只看该作者
有呀
这个是参考UL1993的哪一条款呢,知道的指教一下,谢谢!
GMT+8, 2026-10-17 11:15 , Processed in 0.072898 second(s), 18 queries , Gzip On.
