查看: 378|回复: 2
LED Lamp
发表于 2012-1-27 17:27:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有的LED lamp 要满足environmental pollution degree
但是我只知道有IP code
请问environmental pollution degree 有何标准验证
发表于 2012-1-27 17:27:28 | 只看该作者
environmental pollution degree 是在UL840里对PCB板上电气间距要求的一个分级,LED 灯泡可以参考UL1993中的这段条款:
9.8 When applying the requirements specified in UL 840 to determine environmental pollution, the device
can be evaluated with different environmental pollution degrees. The following conditions apply:
a) A device marked for damp or wet use shall be exposed to environmental pollution degree 3.
b) A device intended for dry locations shall be exposed to environmental pollution degree 2.
c) The portion of a printed wiring board covered with a potting compound or a conformal
coating that complies with the requirements in Conformal-Coating Tests, Section 32, shall be
exposed to environmental pollution degree 1.
发表于 2012-1-27 17:27:34 | 只看该作者
是不是光污染?
GMT+8, 2026-10-17 11:42 , Processed in 0.084168 second(s), 18 queries , Gzip On.
