查看: 667|回复: 2
美规接线盒的承重是多少,重型吊灯从灯体
发表于 2012-1-27 17:04:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
重型吊灯(多少磅??)从灯体锁一条钢丝,在接线盒里怎样固定??
发表于 2012-1-27 17:04:23 | 只看该作者
在标准UL1598中有规定的。
发表于 2012-1-27 17:04:29 | 只看该作者
吊灯22.7kg,壁灯11.4kg,参考标准条款如下:
10.2.5 A luminaire, including lamps, shall be provided with means of support independent of the outlet box and shall be marked and provided with installation instructions in accordance with Table 20.1.1, Items 1.21 and 1.33, if it is:
(a) a ceiling surface type and weighs more than 22.7 kg (50 lb); or
(b) a surface wall-mounted type and weighs more than 11.4 kg (25 lb).
GMT+8, 2026-10-17 11:42 , Processed in 0.107295 second(s), 18 queries , Gzip On.
