查看: 488|回复: 4
III类灯具插头
发表于 2012-1-27 16:37:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教,一般插头是需要有认证,III类灯具的插头有何要求???不可使用能插入通用插座的插头?有这一条要求吗?
发表于 2012-1-27 16:37:55 | 只看该作者
不可使用能插入通用插座的插头。
 楼主| 发表于 2012-1-27 16:38:01 | 只看该作者
不可使用能插入通用插座的插头。
那只能使用特殊插头吗???!!!
发表于 2012-1-27 16:38:07 | 只看该作者
要是有图可以参考下就perfect了。。。
发表于 2012-1-27 16:38:13 | 只看该作者
5.2.14 A class III luminaire shall not be provided with a plug which permits connection with a socket outlet according to IEC 60083.
Plugs and socket-outlets for class III luminaires, where a safety isolating transformer is
delivered with the luminaire having rated current ≤3 A and rated voltage ≤25 V a.c. or 60 V d.c.
and power not exceeding 72 W, are allowed to comply only with the following requirements:
– plugs shall not be able to enter socket-outlets of other voltage systems (according to
IEC 60083);
– sockets-outlets shall not admit plugs of other voltage systems;
– socket-outlets shall not have the protective earth contact.
NOTE 2 For this particular plug and socket-outlet system, the ball pressure test given in Section 13
可以参考IEC60598-1 clause 5.2.14.
GMT+8, 2026-10-17 14:10 , Processed in 0.083061 second(s), 19 queries , Gzip On.
