查看: 386|回复: 1
UL1993 5.4.2怎么理解?
发表于 2012-1-27 14:55:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
条款:
5.4.2 A device that is constructed so that the alignment with the existing incandescent luminaire or
portable luminaire requires an adjustment greater than ±20 degrees shall be provided with adjustment of
the device base with relation to the remainder of the device. Examples include:
a) A rectangular-shaped device in which the device is to be parallel with existing walls when
installed in a ceiling surface luminaire, and
b) A device incorporating a ballast compartment or lamp support arms that will in some cases
have to be rotated more than 20 degrees to properly clear harps in portable luminaires.
该怎么理解??
 楼主| 发表于 2012-1-27 14:55:17 | 只看该作者
没人给解释下?
GMT+8, 2026-10-17 14:22 , Processed in 0.025580 second(s), 18 queries , Gzip On.
