查看: 433|回复: 2
UL1993 8.14 water spray test
发表于 2012-1-27 14:07:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问有谁知道UL1993 8.14 water spray test 喷水过程是否要点灯。
如果是LED PAR灯,用于WET LOCATION, 那么是按照UL8750 8.12 environment 测试,还是UL1993?
 楼主| 发表于 2012-1-27 14:07:09 | 只看该作者
帖子不能沉啊
发表于 2012-1-27 14:07:15 | 只看该作者
用UL1993标准来测试,UL8750不包括LED LAMP,8750有描述如下:
Removed: The following definitions were removed as these terms were not referenced
in the standard:
? circuit, extra-low voltage
? circuit, limited current
? circuit, safety extra low voltage
? enclosure, mechanical
? lamp
? LED lamp, integrated
? LED lamp, non-integrated
? LED luminaire
? LED module
? Pollution Degrees (1, 2, and 3)
? power source, Class 2 or Limited Power Source (LPS)
? rated maximum temperature, Tc
GMT+8, 2026-10-17 16:03 , Processed in 0.027467 second(s), 19 queries , Gzip On.
