查看: 722|回复: 2
SELV,关于安全特低电压值的范围(直流120V 交流50V最大值)
发表于 2012-1-26 02:01:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ELV in a circuit which is insulated from the mains supply by an insulation not less than that
between the primary and secondary circuits of a safety isolating transformer according to
IEC 61558-2-6 or equivalent .
NOTE Maximum voltage lower than 50 V a.c. r.m.s. or 120 V ripple free d.c. may be specified in particular requirements, especially when direct contact with current-carrying parts is allowed.
这里边所说的直流电压允许最高值是120V吗?
 楼主| 发表于 2012-1-26 02:01:09 | 只看该作者
120的电压比较高,但是61558(Safety of power transformers, power supply units
and similar)标准里确实说到这一点:
6.101 The rated output voltage shall not exceed 50 V a.c. and/or 120 V ripple-free d.c
发表于 2012-1-26 02:01:15 | 只看该作者
更新标准是这样要求定义的。
GMT+8, 2026-10-17 15:42 , Processed in 0.040267 second(s), 18 queries , Gzip On.
