查看: 363|回复: 0
关于低压灯标准条款
发表于 2012-1-26 00:40:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位达人,小弟想请教一个问题:在UL1838标准里面的56.6 The shipping container shall indicate that the luminaire or ?tting is only for use with low voltage
landscape lighting power units with a maximum output rating of ____ volts, 300 watts per secondary,
unless evaluated for other uses. The voltage shall not exceed the voltage of the system or 15 volts. The
marking shall be in Form A-3中的Form A-3是指那个表呢?小弟找不到啊.请指教.谢!
GMT+8, 2026-10-17 18:30 , Processed in 0.044141 second(s), 18 queries , Gzip On.
