查看: 473|回复: 3
LED手电筒用电源标准
发表于 2012-1-26 00:38:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问,可充电式 LED手电筒 做SASO认证 所用的电池充电器做什么标准 ??
一定是作为LED Driver来做认证吗 即IEC61347-2-13
或者做为POWER SUPPLY
即做标准 IEC61558-2-17 IEC61558-2-6
可没可能做为电池充电器来认证 即做IEC60335-2-29 ???
发表于 2012-1-26 00:39:03 | 只看该作者
It is really a difficult question. Personally, I think
?? - the IEC61347-1+IEC61347-2-13 is applicable to the supply circuitry inside LED Torch
?? - the IEC60335-1+IEC60335-2-29 is used to test the external battery charger if it is sold with the LED Torch
?? - the IEC61558-1+IEC61558-2-17 (or IEC61558-2-6) is used only if the charger is not sold with the LED Torch and the charger is considered as the general purpose adaptor.
As my points may be wrong, I would like to hear more ideas in the forum. Anyone here can voice out his opinions openly.
Thank you!
 楼主| 发表于 2012-1-26 00:39:09 | 只看该作者
那么LED手电筒用3节AAA 7号电池供电(内置,和传统手电筒一样) ,可以用外置充电器充电,电池是可以取出更换的,那充电器是属于第几种情况??
发表于 2012-1-26 00:39:15 | 只看该作者
LS的情况就应该算IEC60335-1+IEC60335-2-29 即GB4706.18。
但有个问题,手机电池的充电器怎么又不按上面的标准执行?由其是不与手机连接,仅用于手机电池的充电器。
GMT+8, 2026-10-17 17:10 , Processed in 0.070805 second(s), 18 queries , Gzip On.
