查看: 405|回复: 2
出口英国 夜灯 保险丝安装问题
发表于 2012-1-26 00:08:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出口英国的电源插座安装的夜灯,
按标准要求需配保险丝(熔断器),
这种熔断器是装在插头外可更换的,类似英式插头,
还是
可以装一个普通保险丝在内部线路上。
产品为LED夜灯。
IEC/EN 60598-2-12标准条款如下:
12.6.9 Where integral plug-pins are of a type where the corresponding plug incorporates a
fuse, the mains socket-outlet mounted nightlight shall also incorporate a suitable fuse to
provide overcurrent protection.
Compliance is checked by inspection.
以下两例是欧盟RAPEX通报过的产品描述,是否是针对这个问题的?
2010 - 28 15
1072/10 UNITED KINGDOM Category: Lighting equipment
Product: Night light
Brand: King Avon
Type/number of model: FACTORY CODE YL-2606, Model BB/NL101, Barcode 5017403040200
Description: Night light with automatic sensor, ideal for dark halls and children`s rooms, with free extra bulbs.
Country of origin: Unknown
Fire
The product poses a risk of fire because it does not have any provision for overcurrent protection and the adaptor has inadequately sized pins. As a result the socket can overheat and the mechanical connections between the base and the cover of the adaptor can suffer undue strain when inserting into, or removing from, a socket.
The product does not comply with the Low Voltage Directive (LVD) and with the relevant European standard EN 60598.
2010 - 28 16
1073/10 MALTA Category: Lighting equipment
Brand: Neon Night Light
Type/number of model: Unknown
Description: Plug in night lamps with images that are child appealing. Three types found:
1. Moon and stars
2. Christmas bells
3. Gorilla and monkey drawings.
Country of origin: China
Electric shock
The products pose a risk of electric shock for children because they are child-appealing. They are not fitted with a fuse hence there is no overcurrent protection.
The product does not comply with the Low Voltage Directive (LVD) and the relevant European standard EN 60598.
发表于 2012-1-26 00:08:44 | 只看该作者
这个保险丝装在产品内部。
发表于 2012-1-26 00:08:50 | 只看该作者
小夜灯应该都是直插式的吧,尺寸都不大,怎么可能把保险丝装外面?
GMT+8, 2026-10-17 19:04 , Processed in 0.043320 second(s), 18 queries , Gzip On.
