查看: 627|回复: 3
吊重测试
发表于 2012-1-25 02:50:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想请问一下,美规灯具中,对于固定灯具的吊重测试是怎样的方式?还有吊线灯的吊重测试又是怎样的方式?
发表于 2012-1-25 02:50:45 | 只看该作者
吊重是承重支点的四倍,线吊灯也一样.
发表于 2012-1-25 02:50:51 | 只看该作者
16.15 Loading
16.15.1 A supporting device shall support a load equal to four times the total mass to be supported under
intended operating conditions for 1 h. The load shall be applied in the direction of actual loading
conditions.
16.15.2 Where more than one support is provided, the load shall be distributed as follows:
(a) where the parts supported are no more than 11.3 kg (25 lb), the full load shall be applied to
each support; or
(b) where the parts supported are more than 11.3 kg (25 lb), the distribution of the load shall
be similar to that encountered in the field.
16.15.3 There shall be no deflection or deformation either during or after loading that reduces electrical
spacings or compromises safety.
发表于 2012-1-25 02:50:57 | 只看该作者
灯体重量的四倍----------来做吊重测试
GMT+8, 2026-10-17 19:44 , Processed in 0.027557 second(s), 18 queries , Gzip On.
