查看: 399|回复: 3
ul153和UL1598区分
发表于 2012-1-25 02:29:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位高手,UL153和UL1598的产品是如何区分的呢.
我公司有一款街灯,设计时是完全按UL153来设计(包括带插头的电线),只是在安装时是固定在地面上的,不能移动,像这样的情况申请UL时是按UL153还是按UL1598来申请呢?
发表于 2012-1-25 02:29:06 | 只看该作者
貌似UL1598。
发表于 2012-1-25 02:29:12 | 只看该作者
典型的UL153覆盖范围。
1 Scope
1.1 These requirements cover portable luminaires (portable electric lamps) and subassemblies whose
primary function is task or ambient illumination. These products are provided with a flexible cord and an
attachment plug for connection to a nominal 120-volt, 15- or 20-ampere branch circuit, and intended for
use in accordance with the National Electrical Code, ANSI/NFPA 70.
或者你可以对比一下UL1598标准的Scope:
1 Scope
1.1 This Standard applies to luminaires for use in non-hazardous locations and that are intended for
installation on branch circuits of 600 V nominal or less between conductors in accordance with the
Canadian Electrical Code, Part I (CEC), CSA C22.1, with the U.S. National Electrical Code (NEC),
ANSI/NFPA 70, and with the Mexican National Electrical Code, NOM-001-SEDE.
发表于 2012-1-25 02:29:18 | 只看该作者
汗,管理员正确啊,是UL153。
GMT+8, 2026-10-17 20:12 , Processed in 0.061625 second(s), 19 queries , Gzip On.
