查看: 386|回复: 2
电源线与内部线的接线方式讨论
发表于 2012-1-25 02:27:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电源线的接线处导体-----------是否可以焊焊锡?
Examples of methods deemed efficient to prevent a wire from becoming detached are:
a) wires are retained by a cord anchorage adjacent to the terminals;
b) conductor is clamped by a spring type screwless terminal;
c) the wire conductor is anchored to the tag before soldering, unless breakage close to the soldering place is likely
to occur as a result of vibration;
d) wires are twisted together in a reliable manner;
e) wires are fastened together by insulation tape, sleeves, or the like;
f) the wire conductor is inserted into a hole in a printed board, bent and soldered, the hole having a diameter
slightly greater than the conductor;
g) the wire conductor is securely wrapped around the terminal by means of a special tool (see Figure 19);
h) the wire conductor is crimped to the terminal by means of a special tool (see Figure 19).
The methods under a) to h) apply to internal wiring and the methods under a) and b) to rewireable external flexible
cord
以上是摘自标准EN60598,,,里面的 A,B 适用于外部电线,这样说应该是不可以的------------------------------------各位看如何呢?
发表于 2012-1-25 02:27:13 | 只看该作者
可以的,以前我们有款产品就是焊接的,主要是牢固和满足产品的条件测试,楼主:你的产品是什么?
发表于 2012-1-25 02:27:19 | 只看该作者
得好好学习英语了阿!!!
GMT+8, 2026-10-17 20:25 , Processed in 0.087929 second(s), 18 queries , Gzip On.
