查看: 385|回复: 4
请问LED驱动电源的漏电流是多少
发表于 2012-1-25 02:17:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问各位大虾,接地的LED驱动电源的漏电流是多少?没有接地的又是多少?谢谢!!
发表于 2012-1-25 02:17:06 | 只看该作者
是低压的吧,没有要求.
发表于 2012-1-25 02:17:12 | 只看该作者
在UL 8750里面有写"
8.7.1 A cord-connected unit rated for a nominal 250-V or less supply shall be tested in accordance with this section. Leakage current shall not be more than:
a) 0.5 MIU for a two-wire cord- and plug-connected unit,
b) 0.5 MIU for a three-wire (including grounding conductor) cord-and plug-connected portable unit, and
c) 0.75 MIU for a three-wire (including grounding conductor) cord- and plug-connected stationary or fixed unit.
 楼主| 发表于 2012-1-25 02:17:18 | 只看该作者
非常感谢!!!
发表于 2012-1-25 02:17:24 | 只看该作者
ls 太厉害了啊
GMT+8, 2026-10-17 20:12 , Processed in 0.048846 second(s), 19 queries , Gzip On.
