查看: 428|回复: 4
求教CE认证的问题
发表于 2012-1-25 01:28:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
灯具做CE认证时,内部导线是UL线,可不可以?
还是说一定要欧标的?
发表于 2012-1-25 01:29:04 | 只看该作者
内部线不用认证都可以,只要截面积够,能过高压就行
发表于 2012-1-25 01:29:10 | 只看该作者
Yes, the second floor is right, the most important thing for CE is that which directive you want to aplly for, for example, if EMC directive, it's none of the cable's business, and for the LVD directive, just do some tests to verify the wire or cable's characteristics, perhaps, if you select the cable with the UL or other marks, sometimes, some tests can be exempt...
发表于 2012-1-25 01:29:16 | 只看该作者
内部导线可以用UL的,但最好是用有VDE认证的或者做随机测试
发表于 2012-1-25 01:29:22 | 只看该作者
的确如此的啦!如果是GS的话就必须是VDE的证书或者随机测试啦
GMT+8, 2026-10-17 23:07 , Processed in 0.057763 second(s), 19 queries , Gzip On.
