查看: 412|回复: 3
关于I类可移动式灯具第8章要求
发表于 2012-1-25 01:17:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
关于I类可移动式灯具第8章要求
现有一可移式落地灯,金属外壳,带接地
根据IEC60598-1:2008第8章要求
8.2 Protection against electric shock
8.2.1 Luminaires shall be so constructed that their live parts are not accessible when the
luminaire has been installed and wired as in normal use, and when it is opened as necessaryfor replacing lamps or (replaceable) starters, even if the operation cannot be achieved by hand.
Basic insulated parts shall not be used on the outer surface of the luminaire without
appropriate protection against accidental contact.
NOTE 1 Examples of basic insulated parts are cables intended for internal wiring, controlgear for building-in etc.
No access to live parts with the standard test finger is permitted when the luminaire has been
installed and/or assembled for normal use and, in addition, under the same conditions:
]– for portable luminaires and adjustable luminaires, no access to basic insulated parts with
the standard test finger is permitted, and
– for wall-mounted luminaires, within arms reach, there shall be no access to basic insulated
parts from the outside of the luminaire by means of a Ø 50 mm probe according to Figure 1
in IEC 61032.
NOTE 2 In the context of this section, wall mounted luminaires may need to be considered as portable luminaires
when their mounting and supply connection are as described under the definition 1.2.9 of this standard.
是否就是不合格产品了?
 楼主| 发表于 2012-1-25 01:17:42 | 只看该作者
in IEC 61032
金属外壳,I类,固定式灯具中,有可伸缩的部件,比如现在常见的I类,床头灯,那不是也不行了?
发表于 2012-1-25 01:17:48 | 只看该作者
你这个还要看到灯的具体情况,是否达到安规要求,不是说金属外壳就一定不行
 楼主| 发表于 2012-1-25 01:17:54 | 只看该作者
针对条款,I类的可移式灯具,还有墙壁安装的I类可调式灯具,金属外壳的,行不?
GMT+8, 2026-10-17 22:17 , Processed in 0.028661 second(s), 19 queries , Gzip On.
