查看: 537|回复: 3
LED光源的CLASS1与CLASS2
发表于 2012-1-21 03:21:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问LED光源里面的CLASS1和CLASS2是什么含义?
发表于 2012-1-21 03:22:05 | 只看该作者
转载自....http://www.lasermet.com/resources/classification_overview.php
An Overview of the LED and Laser Classification System in EN 60825-1 and IEC 60825-1
In 2001 the standard governing the safety of laser products in Europe (EN) and Internationally (IEC), was substantially revised and the Classification system was overhauled. This resulted in the introduction of three new laser classes (1M, 2M and 3R) and the abolition of Class 3A. Below is a brief description of each of the current laser classes.
The 60825-1 standards apply equally to lasers and LEDs. In most places we have used the word "laser", but it can be replaced by "LED". Generally speaking LEDs would be in the lower Classes (1, 1M, 2, 2M, 3R), but very exceptionally may be Class 3B. At the time of writing we are not aware of any Class 4 LEDs*.
Class 1
This class is eye-safe under all operating conditions.
Class 1M
This class is safe for viewing directly with the naked eye, but may be hazardous to view with the aid of optical instruments. In general, the use of magnifying glasses increases the hazard from a widely-diverging beam (eg LEDs and bare laser diodes), and binoculars or telescopes increase the hazard from a wide, collimated beam (such as those used in open-beam telecommunications systems).
Radiation in classes 1 and 1M can be visible, invisible or both.
Class 2
These are visible lasers. This class is safe for accidental viewing under all operating conditions. However, it may not be safe for a person who deliberately stares into the laser beam for longer than 0.25 s, by overcoming their natural aversion response to the very bright light.
Class 2M
These are visible lasers. This class is safe for accidental viewing with the naked eye, as long as the natural aversion response is not overcome as with Class 2, but may be hazardous (even for accidental viewing) when viewed with the aid of optical instruments, as with class 1M.
Radiation in classes 2 and 2M is visible, but can also contain an invisible element, subject to certain conditions.
Classes 1M and 2M broadly replace the old class 3A under IEC and EN classification. Prior to the 2001 amendment there were also lasers which were Class 3B but were eye-safe when viewed without optical instruments. These lasers are Class 1M or 2M under the current Classification system.
Class 3R
Radiation in this class is considered low risk, but potentially hazardous. The class limit for 3R is 5x the applicable class limit for Class 1 (for invisible radiation) or class 2 (for visible radiation). Hence CW visible lasers emitting between 1 and 5 mW are normally Class 3R.
Visible class 3R is similar to class IIIA in the US regulations.
Class 3B
Radiation in this class is very likely to be dangerous. For a continuous wave laser the maximum output into the eye must not exceed 500mW. The radiation can be a hazard to the eye or skin. However, viewing of the diffuse reflection is safe.
发表于 2012-1-21 03:22:11 | 只看该作者
CLASS1是最安全的,任何地方均可使用;
CLASS2使用时,就要有防护措施了。
发表于 2012-1-21 03:22:17 | 只看该作者
我完全同意2楼的看法!
GMT+8, 2026-10-18 00:21 , Processed in 0.076288 second(s), 18 queries , Gzip On.
