查看: 707|回复: 7
灯具电线打结防拉结构问题
发表于 2012-1-21 03:20:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不能采取别的措施吗?打结基本是通不过的!
发表于 2012-1-21 03:20:36 | 只看该作者
最好采用软线固定架!·
发表于 2012-1-21 03:20:42 | 只看该作者
最好采用软线固定架!·
除UL允许打结外,其它地区是不接受打结的。
发表于 2012-1-21 03:20:48 | 只看该作者
打结肯定是美洲灯具,应当不存在通不过的问题,关键是判定标准不对,不要看线皮的位移,把电源线内部接点断开,如果铜丝没有位移是算通过的.这种线皮的移动是可以接受的,不过结打好点是应该的.
发表于 2012-1-21 03:20:54 | 只看该作者
版主的解说是很正确的。打结是需要有些技巧的,打好先用手拉拉,再测试。
发表于 2012-1-21 03:21:00 | 只看该作者
IEC/EN/GB 60598-1 clause 5.2.10 提到电源线需要使用cord anchorage ,摘录如下:
5.2.10 Luminaires provided with or designed for use with non-detachable flexible cables or cords shall have a cord anchorage such that the conductors are relieved from strain, including twisting, where they are connected to the terminals, and such that their covering is protected from abrasion. It shall be clear how the relief from strain and the prevention of twisting is intended to be effected. For luminaires supplied without a cable or cord, suitable test cables or cords of the largest and smallest sizes recommended by the luminaire manufacturer shall be used for the tests.
It shall not be possible to push the flexible cable or cord into the luminaire to such an extent that the cable or cord is subjected to undue mechanical or thermal stress. Methods such as tying the cable or cord into a knot or tying the ends with string shall not be used.
Cord anchorage shall be of insulating material or be provided with a fixed insulating lining if an insulation fault on the cable or cord could make accessible metal parts live.
发表于 2012-1-21 03:21:06 | 只看该作者
打结注意:1是不能太松,不然很容易散开失效;
2是打结位置,预留的线长要足够,不然结还未到位,接线已被拉掉了。
发表于 2012-1-21 03:21:12 | 只看该作者
建议用线扣
GMT+8, 2026-10-18 01:16 , Processed in 0.062977 second(s), 18 queries , Gzip On.
