查看: 381|回复: 2
灯具内的限流装置的问题
发表于 2012-1-21 01:38:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在60598-1 5.3.1.2里说
For wiring which is connected to the fixed wiring via an internal current-limiting device
and limiting the current to 2 A maximum, e.g. lamp current control device, circuit cut-outs,
fuses, protective impedance or isolating transformers,
这里的限流装置包不包括荧光灯用的电感镇流器的?
ballast
unit inserted between the supply and one or more discharge lamps which by means of
inductance, capacitance, or a combination of inductance and capacitance, serves mainly to
limit the current of the lamp(s) to the required value.
发表于 2012-1-21 01:38:42 | 只看该作者
电感镇流器不能作为限流装置吧,
按我的理解,限流装置应该是指电流保险丝一类的东西
不知道是否正确?
 楼主| 发表于 2012-1-21 01:38:48 | 只看该作者
电感镇流器不能作为限流装置吧,
不知道是否正确?
那“lamp current control device”一般指哪些装置呢?
“circuit cut-outs,fuses, protective impedance or isolating transformers”这些都比较明确。
GMT+8, 2026-10-18 03:02 , Processed in 0.061145 second(s), 19 queries , Gzip On.
