查看: 403|回复: 3
help! For portable light,consult a question about wire was p
发表于 2012-1-19 11:34:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
have some part which not clear,so have a help.
For portable light,please the following information(form UL153):
8.4 When wires pass through a joint between sections of a portable luminaire that are separable for
packing purposes, the joint shall be such that rotation of one section with respect to the other during the
assembly of the sections is limited to not more that 360 degrees. Friction alone does not meet the intent
of the requirement to prevent rotation.
Exception: When all of the following conditions exist, rotation between sections of a portable luminaire is
not limited to 360 degrees:
a) The internal diameter of the tubing through which the wires pass is 1/2 inch (12.7 mm) or
more or the Power Supply Cord Twist Test, Section 135A is conducted with acceptable results;
and
b) The rotation during assembly is limited to not more than one revolution for each 3 inches (76
mm) of unobstructed tubing length through which the wires pass, when such rotation does not
place any stress on the conductors; and
c) The conductors do not involve splices unless the splices are:
1) Inaccessible during assembly in accordance with Accessibility of Live Parts, Section
23; and
2) Secured and provided with strain relief that has been shown to be reliable and not
easily defeated by the user.)
有款落地的灯,它是由LAMP BASE,THREE TUBES,LAMPSHADE组成,为了方便装,分开来安装,只要用户按照说明书去安装,在这里就关系到线的问题,TUBE与TUBE 联接之间,就会导致线会旋转360 度,并且线径是小于12.7mm,在此想问一下如何解决这个问题。如果做了电源线扭曲测试,就不能免温升吗。。。请各位大侠提出意见。。。THANKS。。。
发表于 2012-1-19 11:34:07 | 只看该作者
豁免条件标准里已经说得很清楚了,跟标准吧。
135A的测试与免温升无关。我想你是想知道能否general cover吧?我不知道手上是不是最新版的FUII,不敢妄下定论。根据我手上的FUII,章节8.3是需要engineering investigation的,所以不能general cover。
发表于 2012-1-19 11:34:13 | 只看该作者
二楼的大大解说的很仔细, 谢谢
 楼主| 发表于 2012-1-19 11:34:19 | 只看该作者
谢谢楼主,就是想问能不能general cover,为什么做了这个135A测试就不能呢,如果我做了8度测试后,是否还可以呢,
是否有这些内容,可不可以摘录下来,分享一下呵...THANKS
GMT+8, 2026-10-18 05:58 , Processed in 0.065887 second(s), 18 queries , Gzip On.
