查看: 468|回复: 4
影视灯座温升测试不过,如何整改
发表于 2012-1-19 10:51:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
影视灯灯座 220-240V, 250W,50HZ
标准依据:EN 60838-1 10.4 Contacts and all other current-carrying parts shall be so constructed as to prevent excessive temperature rise. The holder contacts are bridged by means of a tes**p, having nominal dimensions, inserted
in the holder, the terminals of which are fitted with conductors of the maximum cross-sectional area for which the holder is intended. The lampholder is loaded for 1 h with 1,25 times its rated current.The temperature rise of the contacts shall not exceed 45 K. This temperature is determined with the aid of melting particles or by thermocouples, not by means of thermometers.
灯座与灯头接触点周围塑料材质粘点,加载1H,1.25倍的额定电流,温升有71.5度,超过标准规定的45K.
请问各位:标准中的contacts 该怎样理解呢,温升粘点具体位置?
还有一个问题:
如何整改?
个人认为,按照标准,使用一般灯泡的灯座都过不了,除非使用冷光源!
 楼主| 发表于 2012-1-19 10:51:25 | 只看该作者
自己顶一下,急需解惑。。。
 楼主| 发表于 2012-1-19 10:51:32 | 只看该作者
怎么看的人多。。。
等待中
发表于 2012-1-19 10:51:38 | 只看该作者
EN 60838-1 是什么标准,与EN 60598-1是什么有关系?
发表于 2012-1-19 12:39:59 | 只看该作者
等待中。。。。。
GMT+8, 2026-10-18 05:58 , Processed in 0.177626 second(s), 18 queries , Gzip On.
