查看: 763|回复: 3
关于UL1838问题:
发表于 2012-1-19 09:52:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
因UL1838标准更新,小弟对这两点不是好明白,译不通啊,所以请各位帮忙译下,我们应该怎样做呢?
56.6 The shipping container shall indicate that the luminaire or fitting is only for use with low
voltage landscape lighting power units with a maximum output rating of ____ volts, 300 watts per
secondary, unless evaluated for other uses. The voltage shall not exceed the voltage of the system or 15 volts. The marking shall be in Form A-3.
57.3 The instructions for other than a pond and small decorative fountain luminaire shall include
the statements ²WARNING – Risk of Electric Shock. Install all luminaires 10 feet (3.05 m) or more from a pool, spa, or fountain.²
 楼主| 发表于 2012-1-19 09:52:21 | 只看该作者
有没有高手啊,帮个忙吧
发表于 2012-1-19 09:52:27 | 只看该作者
好像这个标准做的少,你把标准传上来让别人看看,保证有高手指点迷津
发表于 2015-10-27 14:26:46 | 只看该作者
UL1838-2009
UL 1838-2009 Low Voltage Landscape Lighting Systems.rar
1.03 MB, 下载次数: 10, 下载积分: 金币 -1
GMT+8, 2026-10-17 17:30 , Processed in 0.030605 second(s), 20 queries , Gzip On.
