查看: 402|回复: 1
Safety extra low voltage
发表于 2012-1-19 09:47:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教一个问题:
在IEC60598-1(2008)中,SELV(Safety extra low voltage)定义如下:
ELV in a circuit which is insulated from the mains supply by an insulation not less than that between the primary and secondary circuits of a safety isolating transformer according to IEC 61558-2-6 or equivalent.
NOTE Maximum voltage lower than 50V a.c. r.m.s. or 120V ripple free d.c. may be specified in particular requirements, especially when direct contact with current-carrying parts is allowed.
请问应该如何理解?灯具在什么情况下才能算是安全特低电压的灯具呢?
 楼主| 发表于 2012-1-19 09:47:55 | 只看该作者
另外一个问题,安全特低电压是否人体可以接触?即在设备漏电的情况下,人体接触不会产生危险?
GMT+8, 2026-10-18 10:12 , Processed in 0.056892 second(s), 18 queries , Gzip On.
