查看: 479|回复: 5
出口老美的dimmer(indoor user only),用哪个标准?Somebody h
发表于 2012-1-18 20:09:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大侠、前辈指点小弟,出口美国的家用调光器用哪个标准?
发表于 2012-1-18 20:10:05 | 只看该作者
原文 出口老美的dimmer(indoor user only),用哪个标准?Somebody help me? :
做欧洲用EN61058标准,做美国就不是很清楚了,最好问一下测试公司.
 楼主| 发表于 2012-1-18 20:10:11 | 只看该作者
总版主,EN61058是电子开关(Standard for Special-Use Switches)VDE的测试标准吧???能作为dimmer的欧洲标准吗?
发表于 2012-1-18 20:10:17 | 只看该作者
去年我做的DIMMER就是用这个标准.
发表于 2012-1-18 20:10:23 | 只看该作者
UL 1472 Solid-State Dimming Controls
1 Scope
1.1 These requirements cover permanently installed devices, hereafter referred to as dimmers, that employ a dimming function intended for control of lighting loads of the ballast, transformer, or tungsten-filament type, and are intended to be installed in a wallbox or are provided with an enclosure for flush or surface mounting in accordance with the Canadian Electric Code, Part 1 (CEC), and the National Electrical Code (NEC), ANSI/NFPA 70.
1.2 These requirements cover dimmers, other than touch dimmers, rated 600 volts ac or less, for installation on a 20-ampere or less branch circuit.
1.2A These requirements cover touch dimmers rated 120 volts ac or less for installation on a 20-ampere or less branch circuit.
1.3 These requirements cover dimmers, including touch dimmers, and electronic switches, having a minimum power rating of 300 watts or 300 volt-amperes in increments of 50 watts or 50 volt-amperes.
1.4 A device incorporating other functions (for example, speed control) in addition to a dimming function is investigated on the basis of compliance with the applicable requirements for the dimming function in this Standard as well as requirements for the other functions in the applicable standards.
1.5 These requirements do not cover dimmers that use only a resistor or a transformer to perform the dimming function.
1.6 These requirements do not cover modular, cabinet or console type constructions.
1.6A These requirements do not cover dimmers intended primarily for use in theaters. Dimmers for use in theaters are covered by the Standard for Industrial Control Equipment, UL 508/CSA C22.2 No. 14.
 楼主| 发表于 2012-1-18 20:10:29 | 只看该作者
谢谢四楼的Icky。你的行动是论坛上的楷模,是论坛上的标兵。
GMT+8, 2026-10-18 09:58 , Processed in 0.103262 second(s), 18 queries , Gzip On.
