查看: 423|回复: 3
semi-luminaire
发表于 2012-1-18 20:01:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问什么是semi-luminaire, discharging lamp
发表于 2012-1-18 20:02:01 | 只看该作者
根据IEC 60598-1:2003.查得定义为:
Semi-luminaire:
Unit similar to self-ballasted lamp but designed to utilize a replaceable light source and /or starting device.
Note1: The Lighht source component and/or starting device of a semi luminaire is readily replaceable.
Note2: The ballast component is not replaceable and is not disposed of each time a light source is replaced.
Note3: A lampholder is required for supply connection.
Note4: For examples and further infomation, See IEC 60972
发表于 2012-1-18 20:02:07 | 只看该作者
呵呵,还没接触过半灯具。
 楼主| 发表于 2012-1-18 20:02:13 | 只看该作者
我知道IEC60598里面有这个定义,但我想知道具体几怎样的灯.有没有图片提供啊?
GMT+8, 2026-10-18 09:46 , Processed in 0.027405 second(s), 18 queries , Gzip On.
