查看: 492|回复: 8
请帮忙看什么意思?
发表于 2012-1-18 19:46:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
记得 我是谁不?我说了我换工作了的那个 又回来找你们帮忙了
请帮忙翻译哈下面的测试
Measurement of EBLF shall be made at 25度 using a lamp of the appropriate type and having not been lit for 24,first at V1 after 5s and 60s of the application of the d.c. voltage, then in steady conditions at Vmin
The lowest value of the valuse measured at 60s and V1 or in steady conditions at Vmin shall be retained and shall reach at least the declared EBLF
The value measured at 5s and V1 shall reach at least 50% of declared EBLF
Note Replace 60s by 0.5s for ballasts declared for use in luminaires for high-risk task area lighting As declared EBLF must be reached after 0.5s measurements at 5s are not considered
Any test circuit corresponding to that of figure 1 can be used to make the measurement of EBLF The luminous flux of a lamp is usually measured with an integrating photometer For ratio measurements of lumious fluxes a suitable illuminance meter is sufficient as there is a close ralationship between luminous flux and illumination at a fixed point
NOTE Other methods may apply for determining EBLF in particular methods which record permanently the luminous flux of the lamp associated to the ballast under test
不晓得什么原因 翻译出来的一直不通
请帮忙
TKS!
发表于 2012-1-18 19:46:24 | 只看该作者
有“钱途”的那位MM吧!
上述信息来自什么标准上的,怎么感觉不通?
发表于 2012-1-18 19:46:30 | 只看该作者
太多了点, 帮你翻译第一段:
EBLF应当用一个还没有点亮超过24小时的合适类型的灯泡在25度的温度下测试, 先在申请的直流电压v1下测试5s和60秒的数据, 然後稳定在Vmin电压下测试
 楼主| 发表于 2012-1-18 19:46:36 | 只看该作者
IEC61347-2-7的啊
前面我自己看了哈
后面的实在不通啊
发表于 2012-1-18 19:46:42 | 只看该作者
哪句不通贴哪句, 太多了浪费时间, 很好懂的两句话啊
 楼主| 发表于 2012-1-18 19:46:48 | 只看该作者
不通的都在了啊!
发表于 2012-1-18 19:46:54 | 只看该作者
你有太多的打字错误, 再帮你整一点, 有事去了:
V1电压下60秒时或Vmin电压稳定状态下的测量值中的最小值应当稳定且达到EBLF宣称的最小值
V1电压下5S时的测量值应当至少达到EBLF宣称时的50%
Note Replace 60s by 0.5s for ballasts, declared for use in luminaires for high-risk task area lighting As declared EBLF must be reached after 0.5s measurements at 5s are not considered
此句有语法错误
任何符合图1的测试电路都可以用来测试EBLF.
灯泡的光通量测量通常都是用一体式光度计来测量. 对於光通量测量的比率, 合适的照度计即可测量, 因为光通量和照度在某一点上来说有着极为相近的关系.
 楼主| 发表于 2012-1-18 19:47:00 | 只看该作者
就是这句啊
TKS!!!
发表于 2012-1-18 19:47:06 | 只看该作者
就是这句啊
TKS!!!
意思我明白了, 但是你去对对原文, 肯定有出入, 上面很多错别字啊 , 自己也不检查一下就发上来, 连标点符号都不打!
我猜应当是:
Note:Replace 60s by 0.5s for ballasts declared for use in luminaires for high-risk task area lighting. As declared EBLF must be reached after 0.5s, measurements at 5s are not considered.
你读读就懂了!
GMT+8, 2026-10-18 10:11 , Processed in 0.027145 second(s), 18 queries , Gzip On.
