查看: 535|回复: 8
端子台的固定
发表于 2012-1-18 19:30:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
比如说:一款吸顶灯,端子台是否一定要固定在吸顶盘内?是否可以用加长了爬电距离的端子台,不固定?
发表于 2012-1-18 19:30:18 | 只看该作者
楼主用的是什么端子?
发表于 2012-1-18 19:30:24 | 只看该作者
楼主用的是什么端子?
如果是PA10的接线端子, 标准有规定要固定吗?
发表于 2012-1-18 19:30:30 | 只看该作者
15.3.8 Terminals shall be suitably fixed to the equipment or to a terminal block or otherwise
fixed in position. They shall not work loose when conductors are inserted or withdrawn.
Compliance is checked by inspection and, if there is a doubt, by applying the mechanical test
given in 15.5 or 15.8. During the test, the terminals shall not work loose and there shall be no
damage that will impair their further use.
The above conditions apply not only to terminals which are fixed to equipment but also to
terminals which are delivered separately. Covering with sealing compound without other means
of locking is not sufficient. Self-hardening resins may however be used to lock terminals which
are not subject to torsion in normal use.
15.3.9 Terminals and connections shall withstand the mechanical, electrical and thermal
stresses occurring in normal use.
Compliance is checked by the tests of 15.5, 15.6, 15.8 or 15.9 as appropriate.
发表于 2012-1-18 19:30:36 | 只看该作者
最适当的方法是固定,不然会被判不合格项的.
发表于 2012-1-18 19:30:42 | 只看该作者
应该可以,但也可不回定在吸顶盒子上看客人要求
发表于 2012-1-18 19:30:48 | 只看该作者
我们是可以不固定的哇
不固定会有什么安全隐患吗
发表于 2012-1-18 19:30:54 | 只看该作者
可以不固定,但要有压线装置
发表于 2012-1-18 19:31:00 | 只看该作者
TUV认证该端子一定要固定,不然。。。呵呵
兄弟,”不然“后面是什么呀?说到重点就停了。。
GMT+8, 2026-10-18 09:44 , Processed in 0.029020 second(s), 18 queries , Gzip On.
