查看: 659|回复: 4
澳洲发布了60335-2-9的A1,针对多士炉结构的专门要求
发表于 2012-1-17 10:29:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
澳大利亚标准组织今天发布了AS/NZS 60335.2.9/A1:2011,其内容可以在SAI global的网站免费下载。看了一下,内容主要是修改了22.113针对多士炉的弹射装置,提出了专门要求。
由于欧洲还没有发布针对IEC 60335-2-9:2008的EN版本,所以欧洲什么要求还不知道。
内容如下,大家可以探讨一下:
22.113 Replace the text by the following.
Toasters having an ejector mechanism shall be constructed so that they switch off
automatically after the normal toasting time even if the ejector mechanism is
blocked by the bread.
Furthermore, toasters having an ejector mechanism shall be constructed so that
they switch off automatically after the normal toasting time even if the operating
lever is held down. This requirement is not applicable to toasters having an ejector
mechanism if the operating lever is recessed so as to avoid it being inadvertently
held down by a vertically moving roller door or the like.
Compliance is checked by inspection and by the following tests for ejector
mechanisms blocked by the bread and for toasters not having a recessed operating
lever.
The toaster is supplied at rated voltage and the ejector mechanism is prevented
from releasing. On the completion of the normal toasting time, heating elements
shall be automatically disconnected from the supply by at least an all-pole
disconnection, micro-disconnection. However, a single pole, micro-disconnection
is allowed, provided heating elements are not accessible to the test probe 12 of IEC
61032.
For toasters not having a recessed operating lever, the test is repeated, the
toaster being supplied at rated voltage with the operating lever prevented from
releasing. On the completion of the normal toasting time, heating elements shall be
automatically disconnected from the supply by at least an all-pole disconnection,
micro-disconnection. However, a single pole, micro-disconnection is allowed,
provided heating elements are not accessible to the test probe 12 of IEC 61032.
发表于 2012-1-17 10:29:23 | 只看该作者
顶一下,学习了!LZ很关心SAI的动态嘛~~值得学习!
发表于 2012-1-17 10:29:29 | 只看该作者
为何现在TUV对OVEN也增加做A1测试?
发表于 2012-1-17 10:29:35 | 只看该作者
不是吧,怎么我没有听说过?
发表于 2012-1-17 10:29:41 | 只看该作者
看一下事故召回版吧,对吐司炉(烤面包机)有重大召回事件当然要严加重视和把关咯。。。
GMT+8, 2026-9-3 18:15 , Processed in 0.023636 second(s), 18 queries , Gzip On.
