查看: 366|回复: 0
UL859 温升测试问题 求教
发表于 2012-1-16 18:05:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL859 在正常温升时,标准要求:
Appliance is supported as in normal service (NTC side was down)
An electrical heating element intended for application to the hair is to be loaded with a moistened cloth and then operated until the moisture has been evaporated and the heating surface of the unit has attained a temperature of 204°C (400°F). Following a 2 minute period with the unit disconnected, during which it is to be reloaded with another moistened cloth, the heating and evaporating operation is to be conducted a second time. The complete cycle is then to be repeated again. Temperatures are to be measured throughout the test.
我在测试的时候,the heating surface (发热铝板外表面)达不到204度,那我应该如何测试?多久更换一次湿布?
直发器和卷发器都是没有锁扣装置,是否只要测试开夹就可以了?
请教
GMT+8, 2026-9-3 19:23 , Processed in 0.027524 second(s), 18 queries , Gzip On.
