查看: 398|回复: 3
求符合8.1.1而不符合8.1.3的结构的例子
发表于 2012-1-16 18:04:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如果不考虑头部尺寸的微小差别,probe B的手指部分与probe 41的长度相同,而直径小很多。那么什么样的结构会导致符合8.1.1而不符合8.1.3呢?想象不出来。
是不是8.1.3重点针对可见灼热导电部件的支撑件?
发表于 2012-1-16 18:04:20 | 只看该作者
for example: toaster
 楼主| 发表于 2012-1-16 18:04:26 | 只看该作者
难道没有这种结构吗?
标准这一条怎么理解?
发表于 2012-1-16 18:04:32 | 只看该作者
标准上已经写得很清楚,class II产品除外的其它产品用8.1.3
8.1.3 Instead of test probe B and test probe 13, for appliances other than those of class II, test probe 41 of IEC 61032 is applied with a force not exceeding 1 N to live parts of visibly glowing heating elements, all poles of which can be disconnected by a single switching action. It is also applied to parts supporting such elements, provided that it is obvious from the outside of the appliance, without removing covers and similar parts, that these supporting parts are in contact with the element. It shall not be possible to touch these live parts. NOTE For appliances provided with a supply cord and without a switching device in their supply circuit, the withdrawal of the plug from a socket-outlet is considered to be a single switching action.
GMT+8, 2026-9-3 19:23 , Processed in 0.027759 second(s), 19 queries , Gzip On.
