查看: 365|回复: 0
UL1727商用个人护理产品的电源线要求
发表于 2012-1-16 17:20:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
14.4.6 The flexible cord shall be of a type indicated in Table 14.7 or the equivalent.
Appliance on which cord is to beused
Cords acceptable where
temperatures higher than 121°C
(250°F) are attained on any surfacethe cord can touch
Cords acceptable where 121°C
(250°F) or lower temperatures are
attained on any surface the cord cantouch
Floor supported
HSJ, HSJO, HS, HSO
HSJ, HSJO, HS, HSO, SJ, SJE, SJO,SJT, SJTO, S, SE, SO, ST, STO
Hand-supported hair dryers, heated-air
curling irons and brushes, and countersupportedappliances
HPD, HPN, HSJ, HSJO
HPD, HPN, HSJ, HSJO, SP-2, SPE-2,
SPT-2, SV, SVE, SVO, SVT, SVTO,SJ, SJE, SJO, SJT, SJTOFacial saunas
-SP-2, SPE-2, SPT-2
Combs
SP-2, SPE-2, SPT-2, HPN
Curling irons and brushes, hair-crimping
and hair-straightening irons, and similarhand-supported appliances
TPTHPN
a, SP-1, SPE-1, SPT-1, XTb, HPD,
TPTSPT-1, SPT-2, XTa, SP-1, SP-2, SPE-1, SPE-2,b, HPD, HPNManicure and pedicure sets
-SP-2, SPE-2, SPT-2
Type TPT cord may be used with appliances rated 50 watts or less and weighing 1/2 pound (454 g) or less. The weightis to be determined without the power supply cord.
b
Minimum 20 AWG (0.52 mm2) parallel, 2-conductor construction required.
问题: 黄色高亮部分有列SPT-2,SVT电线,红色高亮部分是没有具体写到SVT,那么红色部分涵盖的产品能用SVT的电线吗?
GMT+8, 2026-10-25 10:49 , Processed in 0.079495 second(s), 18 queries , Gzip On.
