查看: 387|回复: 1
en 60335-2-29输出电流测试
发表于 2012-1-15 17:59:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
10.102 The arithmetic mean value of the output current shall not deviate from the rated d.c.
output current by more than 10 %.
Compliance is checked by connecting the battery charger to the circuit of Figure 101. The
battery charger is supplied at rated voltage and the variable resistor is adjusted to obtain the
rated d.c. output voltage. The output current is then measured.
请问大家怎么理解en 60335-2-29输出电流测试这段话呀,输出电流允许的限值是不超过10%还是正负10%的限值?
发表于 2012-1-15 17:59:42 | 只看该作者
正负10%
GMT+8, 2026-10-19 11:56 , Processed in 0.027853 second(s), 18 queries , Gzip On.
