查看: 449|回复: 1
UL 250 对接地电阻值的要求
发表于 2012-1-15 17:43:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL250中如果接地部件中没有非金属,都不用测接地电阻值?
只在9.15 Grounding continuity test中提到:
9.15.1 After conditioning as specified in Clause 9.15.2, a grounding connection that relies on the integrityof a polymeric part shall have a resistance of not more than 150 percent of the as-received value. In anycase, the resistance of the connection shall not exceed 0.1 ohm.
好难理解。
 楼主| 发表于 2012-1-15 17:43:43 | 只看该作者
真的没有对接地电阻值的要求吗?
GMT+8, 2026-10-19 00:36 , Processed in 0.097305 second(s), 18 queries , Gzip On.
