查看: 519|回复: 4
关于空调互联软线的考核要求
发表于 2012-1-15 17:36:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
记得这根互联线是要按照电源线的要求进行考核的,这个在标准里有明确的说明吗?
例如也要判连接方式,也要有软线固定装置,等等。
标准里在哪里提到的啊?
谢谢!
发表于 2012-1-15 17:36:46 | 只看该作者
要按电源线要求。
25.23 Interconnection cords shall comply with the requirements for the supply cord,
except that
– the cross-sectional area of the conductors of the interconnection cord is determined on
the basis of the maximum current carried by the conductor during the test of clause 11 and
not by the rated current of the appliance;
– the thickness of the insulation of the conductor may be reduced if the voltage of the
conductor is less than the rated voltage.
Compliance is checked by inspection, by measurement and if necessary by tests, such as the
electric strength test of 16.3.
发表于 2012-1-15 17:36:52 | 只看该作者
按照实际温升和电流来判定用几号线,用什么材质就要看你对质量的要求!
发表于 2012-1-15 17:36:58 | 只看该作者
空调的互联软线型号的选择在空调的特殊要求中有注明。
发表于 2012-1-15 17:37:04 | 只看该作者
特标25章
GMT+8, 2026-10-18 18:54 , Processed in 0.192268 second(s), 19 queries , Gzip On.
