查看: 602|回复: 2
UL1278 电暖器过压测试
发表于 2012-1-15 17:28:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL1278标准中对过压测试规定如下:
41.2.1 The heater it is to be operated at a voltage in accordance with 39.1.12 until constant temperatures
are attained, following which it is to be operated for 2 hours at a 12 percent higher voltage.
期中“12 percent higher voltage”实际测试时,是不是输入额定电压的112%呀?
发表于 2012-1-15 17:28:49 | 只看该作者
按39.1.12运行加热器直到达到恒定温度,然后以该电压的112%的电压运行2个小时。
发表于 2014-4-1 10:27:12 | 只看该作者
不错,学习了,谢谢
GMT+8, 2026-10-17 12:39 , Processed in 0.025677 second(s), 17 queries , Gzip On.
