查看: 425|回复: 5
最新toaster 结构要求
发表于 2012-1-15 17:04:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
根据IEC 60335-2-9:2008 22.113的最新要求, 需要将toaster外面的手柄按住后, 最长周期结束后吐司机全级断开 有哪些机构这么考核了?这个结构很难更改
发表于 2012-1-15 17:04:46 | 只看该作者
一直都是这样要求的吧。厂家最清楚这种结构的。
 楼主| 发表于 2012-1-15 17:04:52 | 只看该作者
怎么改的?据我所知好像很难改的
发表于 2012-1-15 17:04:58 | 只看该作者
怎么改的?据我所知好像很难改的
19.102 Toasters, loaded with the bread specified for normal operation, are operated at
rated power input. The ejector mechanism is prevented from releasing and the supply is
maintained to the toaster after the timer has completed its maximum cycle.
22.113 Toasters having an ejector mechanism shall be constructed so that they switch off
automatically after the normal toasting time even if the ejector mechanism is blocked.
Compliance is checked by the following test.
The toaster is supplied at rated voltage and the ejector mechanism is prevented from
releasing.
On the completion of the normal toasting time, heating elements shall be
automatically disconnected from the supply by at least an all-pole disconnection, microdisconnection.
However, a single pole, micro-disconnection is allowed, provided heating
elements are not accessible to the test probe 12 of IEC 61032
简单回顾一下标准,我认为 22.113 和 19.102 考核的东西其实没什么特别变化。
除非你的产品在 19.102测试中是烧了通天都没事,而通过测试的;否则厂家应该知道该结构要点。
发表于 2012-1-15 17:05:04 | 只看该作者
之前也遇到过同样的疑问(对于可以放入一片面包以上的),其实这主要是对弹出装置的理解:
理解1,如果认为整个包括手柄在内的整个开关为弹出装置就是,按住手柄不放;
理解2,如果认为其中一边的弹簧失效或卡住的话,就用重物压着不让一边弹出。
个人就认为第二种比较像是标准中描述的状况
 楼主| 发表于 2012-1-15 17:05:10 | 只看该作者
目前新西兰已经要求按照第一种测试, IEC这边可能也在投票了
GMT+8, 2026-10-18 18:54 , Processed in 0.026275 second(s), 19 queries , Gzip On.
