查看: 602|回复: 0
吸尘器EK1 498-11决议问题请教
发表于 2012-1-11 21:34:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近IEC60335-2-2吸尘器刚出现了EK1 498-11决议,里面有几个测试,想请教高手。
Additional requirement on bursting strength of the filter:
If the machine is provided with a safety switch to protect the motor and the filter system, this switch must be rendered inoperative. All parts, with the exception of the main filter, can be dried in order to facilitate the flow of the clogging media. All bags and prefilters must be removed from the machine to ensure that the main filter is fully exposed to the clogging media and to the impelling force by covering the intake opening.
By using the method to measure Pi, as described in DIN EN 60335-2-69, Section 3.1.9, a clogging media (e.g. talcum powder) is vacuumed until 90 % of the maximum differential pressure has been reached. Afterwards, the intake opening of the machine is covered for 5 seconds and then opened for 1 second in order to obtain an impulse effect. The test with pulsating air flow must be repeated 30 times within 3 minutes.
The main filter may not exhibit any damages (e.g. breaking, loosening, crack formation).
这个应该是使用堵塞物(如滑石粉)使器具的压力达到最大差动压力的90%,然后通过密封进气口5s、放开1s的方法来获得脉冲效果30次。但是我不知道怎样使压力打到90%,具体怎么操作,压力怎么测?
GMT+8, 2026-10-18 18:12 , Processed in 0.027932 second(s), 18 queries , Gzip On.
