查看: 405|回复: 0
求教:怎样确定温升测试时间?
发表于 2012-1-11 20:05:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看了寒烟翠以下链接的文章后,真是受益颇多。只是对试验稳定条件建立时所对应的时间没有明确的定义。
http://www./read.php?tid=8740
在有些标准中有定义:
1.引用kuiyin001 \Hand-held appliances are operated for 20 min.
Other appliances are operated until steady conditions are established.--60335-2-32 章节11.7
2.The temperature is considered to be stabilized when three successive readings, taken at intervals of 10 percent of the previously elapsed duration of the test but not less than 5 minutes indicate no change.---UL859 /37.1.10
3.引用caballo3157
IEC60598:
12.4.1 f Measurements shall not be taken until the luminaire has stabilized thermally, i.e. temperatures are changing at a rate less than 1 °C per hour.
UL1029:
21.1.6 A thermocouple-measured temperature is to be considered constant if three successive readings, taken at not less than 15-minute intervals, indicate no upward change.
UL1278:
39.1.8 To determine whether a heater complies with the requirement in 39.1.1, it is to be operated continuously until constant temperatures have been reached. A temperature is considered to be constant when three successive readings, taken at intervals of 10 percent of the previously elapsed duration of the test (but not less than 5-minute intervals), indicate no change.
4. 引用寒烟翠:所谓的稳定的意思是一个小时内温度上升不超过1度就可以停止测试,当然是指所有的点;不知是通标EN60335中哪个章节?5.UL1082第33.1.8条等等
请各路高手多多指点及补充。
GMT+8, 2026-10-18 18:12 , Processed in 0.027946 second(s), 19 queries , Gzip On.
