查看: 353|回复: 1
关于30.2.2章节的灼热丝测试问题
发表于 2012-1-10 22:33:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在60335里 30.2.2中有:
The glow-wire test of IEC 60695-2-11 is not applicable to:
– hand-held appliances;
– appliances that have to be kept switched on by hand or foot;
– appliances that are continuously loaded by hand;
– parts supporting welded connections and parts within a distance of 3 mm of these
connections;
– parts supporting connections in low-power circuits described in 19.11.1 and parts within a
distance of 3 mm of these connections;
– soldered connections on printed circuit boards and parts within a distance of 3 mm of
these connections;
– connections on small components on printed circuit boards, such as diodes, transistors,
resistors, inductors, integrated circuits and capacitors not directly
是不是就是说 例如直发器 属于手持式器具 那非金属材料 灼热丝测试就不用做750度 只要做550度测试就可以了(电流>0.5A)?? 感觉以前直发器外壳材质一般都是做750度灼热丝测试的
求教!!!
发表于 2012-1-10 22:35:06 | 只看该作者
手持式器具是该试验不适用的条件之一。
GMT+8, 2026-10-18 18:12 , Processed in 0.039558 second(s), 19 queries , Gzip On.
